T49x/s Bios Update T490s
mcb
18 März 2009
es gibt ein neues Bios für das T490s / X390:
https://pcsupport.lenovo.com/de/en/...nkpad-t490s-type-20nx-20ny/downloads/DS539062
CHANGES IN THIS RELEASE
Version 1.62-1.17  (Machine types: 20NX, 20NY, 20Q0, 20Q1)
[Important updates]
- Addresses CVE-2019-0185 (https://cve.mitre.org/cgi-bin/cvename.cgi?name=CVE-2019-0185)
- Security fix addresses LEN-29406 ST Microelectronics TPM Firmware ECDSA
[New functions or enhancements]
- Updated the CPU microcode.
   (Note) Above update will show "Self-Healing BIOS  backup progressing ... xx %"
          massage on screen during BIOS update process.
- Updated the Diagnostics module to version 04.11.000.
- Supported for Battery Diagnostics.
- Updated Charging LED to always On while AC adapter was connected.
[Problem fixes]
- Fixed an issue where system entered hibernation suddenly due to critical low
  battery status detected incorrectly.
- Fixed an issue where battery was not charged when AC adapter was connected
  before computer was turned on.
- Fixed an issue where system hang after disabled AMT setting in BIOS setup.
Version 1.09-1.03  (Machine types: 20SC, 20SD)
[Important updates]
[Problem fixes]
- Fixed an issue where BitLocker recovery key prompt appeared when PCR 5 was
  selected in TPM Platform Validation Profile.
Total affig: die jetzt dauerhaft leuchtende LED wenn ein Netzteil drann ist ... :pinch:
Gibt es bei Lenovo sowas wie Userfeedback ?
- Ich möchte das alte Verhalten wiederhaben. (leuchtet nur wenn geladen wird).
- die Downloadseiten bei Lenovo spinnen seit Tagen.
Kann mal bitte jemand berichten: Bei mir kam eine Zertifikatwarnung unter Windows 10 (1809).
:confused:
