Batterie 84+ lädt nicht mehr
arnoze
28 Juli 2014
Hallo Zusammen,
schon am 21.7.2014 hatte ich mich von Ubuntu 12.04.4 i386, mit seit circa einem Jahr sehr gut funktionierendem tlp, aus verschiedenen Gründen aufgemacht, zu dieser Konfiguration zu wechseln:
debian wheezy 7.6.0 amd64
tlp
tlp-rdw
tp-smapi-dkms
acpi-call-tools
arno@Lenovo-ThinkPad-E130:~$ sudo tlp-stat
--- TLP 0.5 --------------------------------------------
+++ Configured Settings: /etc/default/tlp
TLP_ENABLE=1
TLP_DEBUG="bat"
DISK_IDLE_SECS_ON_AC=0
DISK_IDLE_SECS_ON_BAT=2
MAX_LOST_WORK_SECS_ON_AC=15
MAX_LOST_WORK_SECS_ON_BAT=60
SCHED_POWERSAVE_ON_AC=0
SCHED_POWERSAVE_ON_BAT=1
NMI_WATCHDOG=0
DISK_DEVICES="sda"
DISK_APM_LEVEL_ON_AC="254 254"
DISK_APM_LEVEL_ON_BAT="128 128"
SATA_LINKPWR_ON_AC=max_performance
SATA_LINKPWR_ON_BAT=min_power
PCIE_ASPM_ON_AC=performance
PCIE_ASPM_ON_BAT=powersave
WOL_DISABLE=N
SOUND_POWER_SAVE_ON_AC=0
SOUND_POWER_SAVE_ON_BAT=1
SOUND_POWER_SAVE_CONTROLLER=Y
BAY_POWEROFF_ON_BAT=0
BAY_DEVICE="sr0"
RUNTIME_PM_ON_AC=on
RUNTIME_PM_ON_BAT=auto
RUNTIME_PM_ALL=0
USB_AUTOSUSPEND=0
USB_BLACKLIST_WWAN=1
RESTORE_DEVICE_STATE_ON_STARTUP=0
START_CHARGE_THRESH_BAT0=75
STOP_CHARGE_THRESH_BAT0=80
DISABLE_TPACPIBAT=0
+++ System Info
System = LENOVO ThinkPad Edge E130 33588DG
BIOS = H4ET92WW (2.52 ) <-- war vorher 2.50
Release = Debian GNU/Linux 7.6 (wheezy)
Kernel = 3.2.0-4-amd64 x86_64
/proc/cmdline = BOOT_IMAGE=/boot/vmlinuz-3.2.0-4-amd64 root=UUID=... ro initrd=/install/gtk/initrd.gz quiet
+++ System Status
TLP power save = enabled
power source = ac
+++ ThinkPad Extended Battery Functions
tp-smapi = active
tpacpi-bat = active
+++ ThinkPad Battery Status (Main)
/sys/devices/platform/smapi/BAT0/manufacturer = SANYO
/sys/devices/platform/smapi/BAT0/model = 45N1057
/sys/devices/platform/smapi/BAT0/manufacture_date = 2013-01-15
/sys/devices/platform/smapi/BAT0/first_use_date = 2013-04-26
/sys/devices/platform/smapi/BAT0/cycle_count = 65
/sys/devices/platform/smapi/BAT0/design_capacity = 62160 [mWh]
/sys/devices/platform/smapi/BAT0/last_full_capacity = 25770 [mWh]
/sys/devices/platform/smapi/BAT0/remaining_capacity = 210 [mWh]
/sys/devices/platform/smapi/BAT0/remaining_percent = 1 [%]
/sys/devices/platform/smapi/BAT0/remaining_running_time_now = 0 [min]
/sys/devices/platform/smapi/BAT0/remaining_charging_time = not_charging [min] <-- hatte bis dahin geladen ...
/sys/devices/platform/smapi/BAT0/power_now = 0 [mW]
/sys/devices/platform/smapi/BAT0/power_avg = 0 [mW]
tpacpi-bat.BAT0.startThreshold = 75 [%]
tpacpi-bat.BAT0.stopThreshold = 75 [%]
tpacpi-bat.BAT0.forceDischarge = 0
+++ Runtime Power Management
Obwohl ich an diesem Tag mit dem Akku ungefähr 3 1/2 Stunden gearbeitet hatte (man darf also davon ausgehen, dass der noch ganz fit war), geht seitdem kein einziges µA mehr in meinen Akku hinein :'(
Ich habe seither folgende Maßnahmen ergriffen um auszutesten, an was das liegen könnte:
- tlp und alle Abhängigkeiten wieder deinstalliert, weil es nur mit debian noch ging.
- tlp nochmal neu installiert, mit den default settings (und dann wieder die aus Ubuntu).
- Hardreset durchgeführt.
- Bios zurückgesetzt.
- BIOS-Update 2.52 auf das Mainboard geflasht.
- Windows 7 Professional (bäh!) mit den nötigen Treibern für das Powermanagement und ebendem installiert - siehe Anliegende Bilder.
- versucht das Battery Controller Bios zu flashen - siehe oben - da scheint sich was zu zwicken ...
- mit dem Multimeter die Sicherungen auf dem Mainboard gecheckt und für gut befunden - ohne Stromlaufplan eine sch... Sucherei, obwohl ich weiß, an welcher Seite man den Lötkolben anfasst.
Bisher alles ohne Erfolg.
Nun meine Fragen:
Müsste an den Akku-Pins 1(2) und (6)7 nicht die derzeit im Akku anstehende Spannung anliegen? Oder wird die erst vom Controller (über dicke FET) frei geschaltet, wenn der meint, dass alles passt?
Hat jemand noch einen guten Tipp bezüglich Battery Controller Bios Update (Embedded Controller Bios gibt es kein Neueres), oder wie man diesen Winzling zurück setzt?
Oder sehr praktisch wäre, wenn es in meiner näheren Umgebung (Nürnberg) jemanden gäbe, der sich zum testen darauf einlässt, dass ich seinem ThinkPad meinen Akku einschiebe, oder der seinen Akku in mein Gerät lässt … laut Lenovo Homepage passt die 84+ (6 cell) (0A36290) auch zu den ThinkPad E120, E125, E320, E325
Schöne Grüße
Arno
Anlagen:
Battery Controller Version ...
... dann Fehler beim flashen ...
Manchmal half bei mir beten und ihn viele Stunden (>48h) am angestöpselten und ausgeschalteten Gerät zu lassen, aber leider bei weitem nicht bei allen.
