Arch Linux Keymaps
xchrissix95
11 Sep. 2009
Hallo. Auf meinem Rechner laeuft Arch Linux mit Gnome. Ich kann aber keine Deutsche Keymap benutzen, obwohl dies in meiner rc.conf eingestellt ist. Hier meine rc.conf
# /etc/rc.conf - Main Configuration for Arch Linux
# LOCALIZATION
# LOCALE: available languages can be listed with the 'locale -a' command
# HARDWARECLOCK: set to "UTC" or "localtime", any other value will result
#   in the hardware clock being left untouched (useful for virtualization)
# TIMEZONE: timezones are found in /usr/share/zoneinfo
# KEYMAP: keymaps are found in /usr/share/kbd/keymaps
# CONSOLEFONT: found in /usr/share/kbd/consolefonts (only needed for non-US)
# CONSOLEMAP: found in /usr/share/kbd/consoletrans
# USECOLOR: use ANSI color sequences in startup messages
LOCALE="de_DE.UTF-8"
HARDWARECLOCK="UTC"
TIMEZONE="Europe/Berlin"
KEYMAP="de-latin1"
CONSOLEFONT="lat9w-16"
CONSOLEMAP=
USECOLOR="yes"
# HARDWARE
# MOD_AUTOLOAD: Allow autoloading of modules at boot and when needed
# MOD_BLACKLIST: Prevent udev from loading these modules
# MODULES: Modules to load at boot-up. Prefix with a ! to blacklist.
# NOTE: Use of 'MOD_BLACKLIST' is deprecated. Please use ! in the MODULES array.
MOD_AUTOLOAD="yes"
#MOD_BLACKLIST=() #deprecated
MODULES=()
# Scan for LVM volume groups at startup, required if you use LVM
USELVM="no"
# NETWORKING
# HOSTNAME: Hostname of machine. Should also be put in /etc/hosts
HOSTNAME="Dragon"
# Use 'ifconfig -a' or 'ls /sys/class/net/' to see all available interfaces.
# Interfaces to start at boot-up (in this order)
# Declare each interface then list in INTERFACES
#   - prefix an entry in INTERFACES with a ! to disable it
#   - no hyphens in your interface names - Bash doesn't like it
# DHCP: 	Set your interface to "dhcp" (eth0="dhcp")
# Wireless: See network profiles below
#Static IP example
#eth0="dhcp"
eth0="dhcp"
INTERFACES=(eth0)
# Routes to start at boot-up (in this order)
# Declare each route then list in ROUTES
#   - prefix an entry in ROUTES with a ! to disable it
gateway="default gw 192.168.0.1"
ROUTES=(!gateway)
# Enable these network profiles at boot-up.  These are only useful
# if you happen to need multiple network configurations (ie, laptop users)
#   - set to 'menu' to present a menu during boot-up (dialog package required)
#   - prefix an entry with a ! to disable it
# Network profiles are found in /etc/network.d
# This now requires the netcfg package
#NETWORKS=(main)
# DAEMONS
# Daemons to start at boot-up (in this order)
#   - prefix a daemon with a ! to disable it
#   - prefix a daemon with a @ to start it up in the background
DAEMONS=(syslog-ng network netfs crond)
Im Terminal haste garantiert ne deutsche Keymap ;) Der xorg Kram wird wie es im Wiki steht per Hal konfiguriert, siehe /etc/hal/policy/fdi/irgendwas. Weiss nichtmehr so genau ;)
