CHANGES IN THIS RELEASE
Version 5.01 and 5.02
[Important updates]
Nothing.
[New functions or enhancements]
Nothing.
[Problem fixes]
- Connecting with wireless WAN through Fn+F5 On Screen Menu takes time.
- An internal error may happen if a wrong PUK code is input.
- Admin Enabler does not work well.
- 'Enable logging' warning message in Access Connections diag is blank
with Danish OS.
- Connection log entry disappears after disconnecting WAN.
- Cancel on PIN prompt connects Wireless WAN after connected through
Fn+F5 On Screen Menu.
- Access Connections prompt is displayed before the user logs to the
system.
- 3 profiles are created by default with GR SIM.
- HSPA default profile fails to connect with GR SIM.
- Wireless WAN is disconnected after connection.
