(II) RADEON: Driver for ATI Radeon chipsets:
ATI Mobility Radeon HD 2400, ATI RADEON E2400, ATI RV610, ATI RV670,
(II) RADEON(0): MMIO registers at 0x00000000d0100000: size 64KB
(II) RADEON(0): PCI bus 1 card 0 func 0
(II) RADEON(0): Creating default Display subsection in Screen section
(==) RADEON(0): Depth 24, (==) framebuffer bpp 32
(II) RADEON(0): Pixel depth = 24 bits stored in 4 bytes (32 bpp pixmaps)
(==) RADEON(0): Default visual is TrueColor
(II) RADEON(0): vgaHWGetIOBase: hwp->IOBase is 0x03d0, hwp->PIOOffset is 0x0000
(==) RADEON(0): RGB weight 888
(II) RADEON(0): Using 8 bits per RGB (8 bit DAC)
(--) RADEON(0): Chipset: "ATI Mobility FireGL 7800 M7 LX (AGP)" (ChipID = 0x4c58)
(--) RADEON(0): Linear framebuffer at 0x00000000e8000000
(II) RADEON(0): AGP card detected
(II) RADEON(0): initializing int10
(II) RADEON(0): Primary V_BIOS segment is: 0xc000
(II) RADEON(0): Legacy BIOS detected
(II) RADEON(0): [dri] Found DRI library version 1.3.0 and kernel module version 1.29.0
(==) RADEON(0): Page Flipping disabled
(II) RADEON(0): Will try to use DMA for Xv image transfers
(II) RADEON(0): Detected total video RAM=32768K, accessible=65536K (PCI BAR=131072K)
(--) RADEON(0): Mapped VideoRAM: 32768 kByte (64 bit DDR SDRAM)
(II) RADEON(0): Color tiling enabled by default
(II) RADEON(0): Max desktop size set to 2048x1200
(II) RADEON(0): For a larger or smaller max desktop size, add a Virtual line to your xorg.conf
(II) RADEON(0): If you are having trouble with 3D, reduce the desktop size by adjusting the Virtual line to your xorg.conf
(II) RADEON(0): ref_freq: 2700, min_out_pll: 12000, max_out_pll: 35000, min_in_pll: 40, max_in_pll: 3000, xclk: 18300, sclk: 183.000000, mclk: 260.000000
(II) RADEON(0): PLL parameters: rf=2700 rd=12 min=12000 max=35000; xclk=18300
(II) RADEON(0): Bios Connector table:
(II) RADEON(0): Port0: DDCType-0x60, DACType-1, TMDSType-1, ConnectorType-1
(II) RADEON(0): Port1: DDCType-0x64, DACType-2, TMDSType-1, ConnectorType-3
(II) RADEON(0): Port4: DDCType-0x0, DACType-0, TMDSType-0, ConnectorType-7
(II) RADEON(0): Port5: DDCType-0x0, DACType-2, TMDSType-0, ConnectorType-5
(II) RADEON(0): Output VGA-0 using monitor section Configured Monitor
(II) RADEON(0): I2C bus "VGA-0" initialized.
(II) RADEON(0): Output DVI-0 has no monitor section
(II) RADEON(0): DFP table revision: 2
(II) RADEON(0): I2C bus "DVI-0" initialized.
(II) RADEON(0): Output LVDS has no monitor section
(II) RADEON(0): Panel ID string: 1600x1200
(II) RADEON(0): Panel Size from BIOS: 1600x1200
(II) RADEON(0): BIOS provided dividers will be used.
(WW) RADEON(0): LVDS Info:
(II) RADEON(0): Output S-video has no monitor section
(II) RADEON(0): Default TV standard: NTSC
(II) RADEON(0): TV standards supported by chip: NTSC PAL NTSC-J
(II) RADEON(0): Port2:
(II) RADEON(0): Port3:
(II) RADEON(0): I2C device "VGA-0:ddc2" registered at address 0xA0.
(II) RADEON(0): I2C device "VGA-0:ddc2" removed.
(II) RADEON(0): Output: VGA-0, Detected Monitor Type: 0
(II) RADEON(0): I2C device "DVI-0:ddc2" registered at address 0xA0.
(II) RADEON(0): I2C device "DVI-0:ddc2" removed.
(II) RADEON(0): Output: DVI-0, Detected Monitor Type: 0
(II) RADEON(0): Output: LVDS, Detected Monitor Type: 0
(II) RADEON(0): Output: S-video, Detected Monitor Type: 0
in RADEONProbeOutputModes
(II) RADEON(0): Added native panel mode: 1600x1200
(II) RADEON(0): Total number of valid Screen mode(s) added: 0
(II) RADEON(0): Output VGA-0 disconnected
(II) RADEON(0): Output DVI-0 disconnected
(II) RADEON(0): Output LVDS connected
(II) RADEON(0): Output S-video disconnected
(II) RADEON(0): Using exact sizes for initial modes
(II) RADEON(0): Output LVDS using initial mode 1600x1200
(==) RADEON(0): DPI set to (96, 96)
(==) RADEON(0): Using gamma correction (1.0, 1.0, 1.0)
(==) RADEON(0): Using XAA acceleration architecture
(==) RADEON(0): Assuming overlay scaler buffer width is 1536
(II) RADEON(0): MM_TABLE: 01-0c-00-0f-0d-00-00-07-00-00-03-00-00-00
(!!) RADEON(0): For information on using the multimedia capabilities
(!!) RADEON(0): MergedFB support has been removed and replaced with xrandr 1.2 support
(II) RADEON(0): RADEONScreenInit e8000000 0 0
(II) RADEON(0): Dynamic Clock Scaling Disabled
(==) RADEON(0): Using 24 bit depth buffer
(II) RADEON(0): RADEONInitMemoryMap() :
(II) RADEON(0): mem_size : 0x04000000
(II) RADEON(0): MC_FB_LOCATION : 0xebffe800
(II) RADEON(0): MC_AGP_LOCATION : 0xffffffc0
(II) RADEON(0): Depth moves disabled by default
(II) RADEON(0): Using 8 MB GART aperture
(II) RADEON(0): Using 1 MB for the ring buffer
(II) RADEON(0): Using 2 MB for vertex/indirect buffers
(II) RADEON(0): Using 5 MB for GART textures
(II) RADEON(0): Memory manager initialized to (0,0) (1600,5242)
(II) RADEON(0): Reserved area from (0,1200) to (1600,1202)
(II) RADEON(0): Largest offscreen area available: 1600 x 4040
(II) RADEON(0): Will use front buffer at offset 0x0
(II) RADEON(0): Will use back buffer at offset 0xea6000
(II) RADEON(0): Will use depth buffer at offset 0x15f9000
(II) RADEON(0): Will use 2752 kb for textures at offset 0x1d4c000
(II) RADEON(0): [drm] Using the DRM lock SAREA also for drawables.
(II) RADEON(0): [drm] framebuffer handle = 0xe8000000
(II) RADEON(0): [drm] added 1 reserved context for kernel
(II) RADEON(0): X context handle = 0x1
(II) RADEON(0): [drm] installed DRM signal handler
(==) RADEON(0): Using AGP 4x
(II) RADEON(0): [agp] Mode 0x1f000207 [AGP 0x8086/0x1a30; Card 0x1002/0x4c58]
(II) RADEON(0): [agp] 8192 kB allocated with handle 0x00000001
(II) RADEON(0): [agp] ring handle = 0xe0000000
(II) RADEON(0): [agp] Ring mapped at 0xb79b9000
(II) RADEON(0): [agp] ring read ptr handle = 0xe0101000
(II) RADEON(0): [agp] Ring read ptr mapped at 0xb8080000
(II) RADEON(0): [agp] vertex/indirect buffers handle = 0xe0102000
(II) RADEON(0): [agp] Vertex/indirect buffers mapped at 0xb56ce000
(II) RADEON(0): [agp] GART texture map handle = 0xe0302000
(II) RADEON(0): [agp] GART Texture map mapped at 0xb51ee000
(II) RADEON(0): [drm] register handle = 0xd0100000
(II) RADEON(0): [dri] Visual configs initialized
(II) RADEON(0): RADEONRestoreMemMapRegisters() :
(II) RADEON(0): MC_FB_LOCATION : 0xebffe800 0xebffe800
(==) RADEON(0): Backing store disabled
(II) RADEON(0): [DRI] installation complete
(II) RADEON(0): [drm] Added 32 65536 byte vertex/indirect buffers
(II) RADEON(0): [drm] Mapped 32 vertex/indirect buffers
(II) RADEON(0): [drm] dma control initialized, using IRQ 11
(II) RADEON(0): [drm] Initialized kernel GART heap manager, 5111808
(WW) RADEON(0): DRI init changed memory map, adjusting ...
(WW) RADEON(0): MC_FB_LOCATION was: 0xebffe800 is: 0xebffe800
(WW) RADEON(0): MC_AGP_LOCATION was: 0xffffffc0 is: 0xe07fe000
(II) RADEON(0): MC_AGP_LOCATION : 0xe07fe000
(II) RADEON(0): Direct rendering enabled
(II) RADEON(0): Render acceleration enabled
(II) RADEON(0): Using XFree86 Acceleration Architecture (XAA)
(II) RADEON(0): Acceleration enabled
(II) RADEON(0): DPMS enabled
(==) RADEON(0): Silken mouse enabled
(II) RADEON(0): Will use 32 kb for hardware cursor 0 at offset 0x00756200
(II) RADEON(0): Will use 32 kb for hardware cursor 1 at offset 0x0075ad00
(II) RADEON(0): Largest offscreen area available: 1600 x 4034
(II) RADEON(0): Using R200 i2c bus access method
(II) RADEON(0): I2C bus "Radeon multimedia bus" initialized.
(II) RADEON(0): Detected Radeon Mobility, not scanning for Rage Theatre
(II) RADEON(0): Set up overlay video
(II) RADEON(0): Set up textured video
(II) RADEON(0): RandR 1.2 enabled, ignore the following RandR disabled message.
(II) RADEON(0): Setting screen physical size to 423 x 317
