Hallo Forum,
gibt es jetzt ein Lösung um einen Thinkpad T440p vom der SD-Card Slot zu booten?
Hardware, Auszug:
Dazu habe ich folgendes gefunden:
https://forums.lenovo.com/t5/ThinkPad-T400-T500-and-newer-T/T440s-Boot-from-SD-XC-Card/td-p/1494630
https://forums.lenovo.com/t5/ThinkPad-T400-T500-and-newer-T/T420-boot-from-SD-card/td-p/2125324
Kann das der Clover EFI bootloader?
https://sourceforge.net/projects/cloverefiboot/
https://github.com/jloisel/t440p
https://www.win-raid.com/t2375f50-G...EFI-BIOSS-CloAver-EAFI-bootloader-method.html
https://www.hackintosh-forum.de/forum/thread/27637-clover-bootstick-mit-ubuntu-gparted-erstellen/
MfG
xsid
Hardware, Auszug:
lspci
03:00.0 Unassigned class [ff00]: Realtek Semiconductor Co., Ltd. RTS5227 PCI Express Card Reader (rev 01)
lspci -vv
Subsystem: Lenovo ThinkPad T440p
Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx+
Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Latency: 0, Cache Line Size: 64 bytes
Interrupt: pin A routed to IRQ 25
Region 0: Memory at f1500000 (32-bit, non-prefetchable) [size=4K]
Capabilities: <access denied>
Kernel driver in use: rtsx_pci
Kernel modules: rtsx_pci
Sure it can. You just need a little bios hack. Google and you'll find all sorts.
The SD card is attached via PCI-E, rather than USB, which makes it unbootable. You'd have to try to chainload it from your existing boatloader somehow.
MfG
xsid
