- 24 Mai 2015
ThinkPad Universal USB-C Dock | ThinkPad USB-C Dock Gen 2 | ThinkPad Thunderbolt 3 Dock GEN 2 | ThinkPad Hybrid USB-C with USB-A Dock | |
| Hersteller Nr | 40AY0090EU | 40AS0090EU | 40AN0135EU | 40AF0135EU |
| Benutzerhandbuch | Link | Link | Link | |
| Overview and Service Parts | Link | Link | Link | Link |
| Maximum Number of Displays | 3 | Supports up to 3 External Monitors | Supports up to 3 External Monitors with NB Built-in LCD | 2 |
| Connectivity | 1 m USB-C Cable | USB-C cable - 1 meter | TBT3 Cable with 0.7 Meter Länger, 40Gbps | USB-C cable with USB-C to USB-A dongle |
| Video Ports |
| Maximum Resolution | 4K | 1 x 4K @ 60 Hz 2 x 4K @ 30 Hz 3 x 1080p @ 60 Hz Maximum Video Output ( Actual display resolution is subject to the laptop output capability) | 2*DP, 2*HDMI, up to dual 4K@60Hz or UHD 5K@60Hz * | 2 x 4K @ 60 Hz DisplayPort: 3840 x 2160 @ 60 Hz HDMI: 3840 x 2160 @ 60 Hz Bundle DisplayPort 1 & DisplayPort 2 to the monitor: 5120 x 2880 @ 60 Hz Maximum resolution refers to what can be supported by the dock. Actual resolution will vary by laptop. |
| USB Ports | 3 x USB-A 3.1 Gen 2 (10 Gbps, 1 x always-oncharging) 2x USB-A 2.0, 1x USB Type-C (10 Gbps, 5V/3A) | 2 x USB-A 2.0 3 x USB-A 3.1 Gen 2 (10 Gbps, 1 x always-on charging) 1 x USB-C (10 Gbps, 5V, 3A) | 1x USB-C (Thunderbolt 3 compatible); 4x USB 3.1 Gen 2; 1x USB 3.1 Gen 2 with Always-on charging | 2 x USB 2.0 3 x USB 3.1 Gen 2 (10 Gbps, 1 x always power-on) 1 x USB-C (USB data only, 5V, 3A power) |
| Ethernet | RJ45 : Gigabit Ethernet | Gigabit Ethernet | 1x RJ-45 Ethernet 10Base-T/100Base-TX/1000Base-T | Gigabit (RJ-45 Port) |
| Audio | Stereo/Microphone Combo | 1x Audio Connector (3.5mm). | Headphone/Microphone combo | |
| Security | 1x Security-lock slot | Kensington cable lock slot | ||
| Power Adapter | 100 Power Adapter and Power Cord | Includes 135W AC Adapter (Slim Tip) | 135W | |
| Maximum Charging Power | 100W mit 135 Watt Slim Tip Netzteil, 65 Watt mit beiliegendem 90 Watt Netzteil | Maximum Power for Laptop Charging 60W | 90W (with USB-C connection) | |
| Power Button to control system power | Selected ThinkPad Laptops | Selected ThinkPad Systems | ||
| PXE Boot | Selected ThinkPad Laptops | Selected ThinkPad Systems | ||
| MAC Address Pass Through | Selected ThinkPad Laptops | Selected ThinkPad Systems | ||
| Wake-On-LAN | Selected ThinkPad Laptops | Sleep, Hybernation & Power Off Mode | ||
| Warranty | 3-Year Limited | 3-Year Limited | ||
| Supported Systems | 2018/2019 Selected ThinkPad Systems | Selected ThinkPad and Selected Lenovo Systems |
