T
torsten
Guest
Wenn jemand unbedingt mit Rapid Restore arbeiten möchte, hier die von IBM vorgeschlagene Lösung:
IBM Rescue and Recovery with Rapid Restore - Microsoft Syste
Symptom Restore "Restore Points" are not preserved or System Restore errors are logged in Event Viewer
System Restore's Restore Points are not saved in Rapid Restore Ultra's backup. When restoring using Rapid Restore Ultra, System Restore will log an error message in the Windows Event Viewer and if you start System Restore, any prior System Restore Points are not available.
Affected configuration
The following ThinkPad systems running Rapid Restore Ultra
* ThinkPad A20m, A20p, A21e, A21m, A21p, A22e, A22m, A22p, A30, A30p, A31, A31p
* ThinkPad G40
* ThinkPad R30, R31, R32, R40, R40e, R50, R50p
* ThinkPad S30
* ThinkPad T20, T21, T22, T23, T30, T40, T40p, T41, T41p
* ThinkPad X21, X22, X23, X24, X30, X31, X40
* ThinkPad TransNote
Solution (IBM)
If you need to restore to an earlier point in time, use Rapid Restore Ultra to restore to that time, and then use Rescue Files & Folders for any additional data.
Ich würde persönlich lieber gleich eine ordentliche Software wie z.B. Acronis http://www.acronis.com/ verwenden.
* ThinkPad G40
* ThinkPad S30
Solution (IBM)
