TRIM Firmware für Lenovo-gelabelte Samsung SSD (128 GB, Typ MMCRE28G8MXP Version VBM1EL1Q)
chris08
10 Mai 2006
In diesem Thread im Lenovo Forum beschreibt user Blue Frog, wie man die original Samsung Firmware mit TRIM Funktionalität auf eine Lenovo-gebrandete SSD (128 GB, Typ MMCRE28G8MXP Version VBM1EL1Q) flashen kann.
Backup your drive, everything must be erased. Use a partition backup routine so you can just restore it. (I used Windows 7 backup)
Go into bios and change your SATA setting from "AHCI" to "compatible". Remove the SSD. Boot from your USB. (Hit F12 on startup, select to boot from USB drive)
*** One additional step to verify, optional, but would recommend it...
Boot to your USB drive with the SSD still plugged in. Run maindiag.exe to verify that it sees your SSD in this configuration. It will populate the make/serial/firmware fields with the Lenovo info, just reassuring you that it is seeing the correct drive and setup correctly to flash. Then shut down, pull the SSD out and continue below. Do not try to flash it with the model/serial/firmware numbers showing, see note below *****
When you get the C:\ prompt, insert your SSD drive into you laptop (hot plug it in). <-- Important, if you boot with the SSD in, maindiag.exe will detect it as Lenovo and will only half flash it, don't go there, recoverable but ugly. If you hotplug it in after boot to c:\ , maindiag.exe will not display the drive version numbers (lines will have no values) just run flash sequence below and it will work and report successful. If you want to verify the drive it is seeing, do the optional step above.
Run maindiag.exe select number 2, then number 1, then number 4. <--Important that you do all three steps, in this order.
You will see a "Success" message after each step.
Reinsert hard drive, reboot, change bios setting back to ahci, reboot, restore image from backup from whatever boot media you created during backup process. (Again, I used Windows Backup and Windows 7 Installer --> choose recovery and selected my backup file.)
Run Crystal Disk info to reveal you have now enabled TRIM,(AAM) Acoustics Management, (NCQ)Native Command Queuing.
Windows experience went from 5.9 to 7.2 and your firmware is now VBM19C1Q
Yeah!
Ich habe es selbst nicht probiert, aber wollte das den Experimentierwilligen nicht vorenthalten :D
Disclaimer: Ich übernehme keine Garantie, möglicherweise endet die SSD als teurer Briefbeschwerer
UPDATE: hat einwandfrei geklappt! :thumbsup: bin jetzt unter Linux mit trim unter der FW vbm19c1q unterwegs
Yeah!
es juckt mir ja in den Fingern - bin mir noch nicht sicher, obs mir den Garantieverlust Wert ist. Außerdem frage ich mich, wie das in dem von dir verlinkten Thread genannte Lenovo Firmware-Upgrade Tool zu bewerten ist? Hat jemand eine Idee (ist wohl nur für Intel-SSDs wenn ich die Changenotes richtig interpretiere).
Mit dem Grantieverlust ist das natürlich so eine Sache, ich bin aber doch schwach geworden. Soweit ich gesehen habe, ist bei dem Lenovo Update keine neue Foirmware für die Samsung SSDs dabei, sondern wie Du schon geschrieben hast nur für die Intels.
Übrigens hier nochmal die kompletten Infos nach dem Update:
sudo hdparm -I /dev/sda
/dev/sda:
ATA device, with non-removable media
	Model Number:       SAMSUNG MMCRE28G8MXP-0VBL1
	Serial Number:      YCXXXXXXXXXXXXXXX
	Firmware Revision:  VBM19C1Q
Standards:
	Used: ATA/ATAPI-7 T13 1532D revision 1
	Supported: 7 6 5 4
Configuration:
	Logical		max	current
	cylinders	16383	16383
	heads		16	16
	sectors/track	63	63
	CHS current addressable sectors:   16514064
	LBA    user addressable sectors:  250069680
	LBA48  user addressable sectors:  250069680
	Logical/Physical Sector size:           512 bytes
	device size with M = 1024*1024:      122104 MBytes
	device size with M = 1000*1000:      128035 MBytes (128 GB)
	cache/buffer size  = unknown
	Nominal Media Rotation Rate: Solid State Device
Capabilities:
	LBA, IORDY(can be disabled)
	Queue depth: 32
	Standby timer values: spec'd by Standard, no device specific minimum
	R/W multiple sector transfer: Max = 16	Current = 16
	Recommended acoustic management value: 128, current value: 0
	DMA: mdma0 mdma1 mdma2 udma0 udma1 udma2 udma3 udma4 *udma5
	     Cycle time: min=120ns recommended=120ns
	PIO: pio0 pio1 pio2 pio3 pio4
	     Cycle time: no flow control=120ns  IORDY flow control=120ns
Commands/features:
	Enabled	Supported:
	   *	SMART feature set
	    	Security Mode feature set
	   *	Power Management feature set
	   *	Write cache
	   *	Look-ahead
	   *	Host Protected Area feature set
	   *	WRITE_BUFFER command
	   *	READ_BUFFER command
	   *	NOP cmd
	   *	DOWNLOAD_MICROCODE
	    	SET_MAX security extension
	    	Automatic Acoustic Management feature set
	   *	48-bit Address feature set
	   *	Device Configuration Overlay feature set
	   *	Mandatory FLUSH_CACHE
	   *	FLUSH_CACHE_EXT
	   *	SMART error logging
	   *	SMART self-test
	   *	General Purpose Logging feature set
	   *	WRITE_{DMA|MULTIPLE}_FUA_EXT
	   *	64-bit World wide name
	   *	WRITE_UNCORRECTABLE_EXT command
	   *	Segmented DOWNLOAD_MICROCODE
	   *	Gen1 signaling speed (1.5Gb/s)
	   *	Gen2 signaling speed (3.0Gb/s)
	   *	Native Command Queueing (NCQ)
	   *	Host-initiated interface power management
	   *	Phy event counters
	   *	DMA Setup Auto-Activate optimization
	    	Device-initiated interface power management
	   *	Software settings preservation
	   *	Data Set Management TRIM supported
Security:
	Master password revision code = 65534
		supported
	not	enabled
	not	locked
		frozen
	not	expired: security count
		supported: enhanced erase
	6min for SECURITY ERASE UNIT. 6min for ENHANCED SECURITY ERASE UNIT.
Logical Unit WWN Device Identifier: 50000f0056424431
	NAA		: 5
	IEEE OUI	: 0000f0
	Unique ID	: 0XXXXXX
Checksum: correct
Moin,
coole Sache das...
werde mal schauen was mein x201 dazu sagt...
von Lenovo selbst ist ja kein Update mehr zu erwarten...
LG Marcel
Ich habe die Flash Prozedur allerdings etwas abweichend vom Guide durchgeführt:
Backup der ssd von vom Stick gestarteten Linux (dd if=/dev/sda of=/media/data/t400s/ssd_backup.img bs=32M)
- Controller im Bios auf Compatibility stellen
- Dos vom Stick booten
- Festplatte einschieben
- maindiag starten
- Option 2
- reboot
- maindiag starten
- Option 1
- reboot
- maindiag starten
- Option 4
- reboot
- bios auf ahci zurückstellen
- Restore der ssd von vom Stick gestarteten Linux (dd of=/dev/sda if=/media/data/t400s/ssd_backup.img bs=32M)
- reboot
ubuntu startet wieder :thumbsup:
hm - wenn ich den ursprungsthread richtig interpretiere, scheint es möglich zu sein, die lenovo-firmware zurückzuspielen. Das würde das ganze natürlich noch reizvoller machen. Mal sehen ob ich in 10 tagen zeit dafür habe :)
btw wäre doch mal ein howto mit der flashprozedur hin und wieder zurück ne gute sache :whistling:
Mich hat die Neugier, als ich gestern den thread gelesen habe, ebenfalls gepackt und habe direkt die samsung fw aufgespielt.
Hat alles einwandfrei geklappt.
Vielen Dank chris08, für den link! Endlich eine fw die Trim beherrscht.
Hallo Zusammen!
Ich würde auch gerne die neue Firmware auf meine Smasung spielen. Leider verstehe ich die Anleitung nicht komplett, da mein Englisch nicht gerade so gut ist. Ich möchte auch keinen Fehler machen und die Platte schrotten! :-( Kann mir vlt. jemand die einzelnen Schritte nennen!? Das wäre echt super! :-)
Moin,
also x201 hat geklappt ohne Probleme...
Anleitung kommt dann morgen kurz auf deutsch ist nicht schwer...
LG Marcel
Moin,
sorry habs im Stress vergessen setze mich heute abned drann...
ist ganz einfach ;)
LG Marcel
x200t, Lenovo 128GB SSD.
Wie macht ihr das, dass der PC nicht neu startet, sobald ihr die SSD per Hotplug reinschiebt?
Danke
Danke,
nur ist die Option bei mir nicht vorhanden.
Geht das nur, wenn man die SSD nicht als Systemplatte verwendet?
Es gibt bei mir nur die Schreibcacherichtlinien.
Danke
Versteh ich grade nicht :question:
Wie willst du den eine Systemplatte hotswappen, wie soll das gehen, wie stellst du dir das vor.
Oder bin ich am falschen Dampfer?
Ich ging davon aus, dass du versuchst die SSD in einer Dock, U-Base oder U-Bay zu swappen.
Da sollte dann im GM die Möglichkeit gegeben sein, für schnelles entfernen zu optimieren.
Da sollte dann im GM die Möglichkeit gegeben sein, für schnelles entfernen zu optimieren.[/quote]
Ich denke, Ploeve will die SSD nicht unter Windows swappen, sondern die Überprüfung des Flash-Tools umgehen, das ja unter DOS läuft.
Eine Lösung habe ich aber auch nicht, bei mir (T400s) wurde nichts neu gestartet....
Du bootest vom USB-Stick und ohne SSD und sobald das Flash-Tool läuft, schiebst Du die SSD rein und das Notebook startet neu, richtig?
Allo amin.r
Ja, genau.
Boote vom USB Stick ohne SSD.
Sobald ich die reinschiebe startet das x200t neu.
Danke
[quote='Ploeve',index.php?page=Thread&postID=999098#post999098]Allo amin.r
Ja, genau.
Danke[/quote]
Wie gesagt, das t400s startet nicht neu...
Ich würde irgendeinen anderen PC nehmen, der von USB booten kann und einen sata-Anschluss hat.
Einen Adapter von 1,8" auf 2,5" müsstet du ja schon haben, um die MMCRE28G8MXP im x200 zu betreiben, und 2,5" Festplatten kann man ja direkt an einen PC anschließen.
